Disappearing Objects
I've imported Archicad 8.1 objects into 11. When I click on the object, the Image in Archicad will show up the first time (Image for Plan, Elev, 3D - example of what I'm talking about is attached). The object inserts fine, but the next time I open up the Object dbx, it will not show up in the Plan/Elev/3D/etc. image. I have to exit Archicad 11 and go back in for the objects to show up. When the Objects "disappear", it happens not only for my custom objects but for the Archicad 11 objects as well.
Again the JPG example of what's happening is attached to this Post.
1 Reply 1
TomWaltz
If you read around the Forum a little, you'll see that the library object preview disappearing is a pretty common bug in AC11. There's not any fix announced for it, other than wait for the service pack that fixes it.
Tom Waltz
