Learn more
JGoode
Displaying decimal points for area.
how can I get my object to display the amount of decimal points that my project preferences set?
here is my line of code
standard1 = str(room_area, 3, 2)  + " " + units
Thanks
ArchiCAD 27
Windows 10
5 Replies 5
Erwin Edel
Think this is what zone stamps do (display m² based on project preferences), and since they are basically objects, maybe dig around a bit in the script there to see what is going on?
If you mean how to see what the working units are set to, I believe there are some Request statements you can use for Working_lenght_unit etc
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
JGoode
My own zone stamp doesn't do this as it is set in the str to 2 decimal points. I need to automate the 2 decimal points to read the project preferences.
ArchiCAD 27
Windows 10
Erwin Edel
Did a quick dig around in GDL Reference Guide, check page 386, the thing you want to request is AREA_DIMENSION for m²
Or as found in the zone stamp:
area_form = ""													! Format as set in the Preferences
	rrr = request ("Area_dimension", "", area_form)
	room_area	= str (area_form, Temp_CalcArea)
	gross_area	= str (area_form, Temp_GrossArea)
etc
www.leloup.nl
JGoode
Okay I made a bit of progress however I have no idea how to implement the format_string into my string with the area
ArchiCAD 27
Windows 10
JGoode
Never mind, I've got it now. Thanks very much for your help.
ArchiCAD 27
Windows 10
