Andrew Reynolds1
Can falls be expressed in say 1:40 (1 in 40) or 1:30.5 (1 in 39.48) rounded down to the nearest
Can falls be expressed in say 1:40 (1 in 40) or 1:30.5 (1 in 39.48) rounded down to the nearest decimal not just in degrees and percentages. Points can be an average across two points in a mesh or accurate across two points. Can this also be on the measure toll please?
3 Replies 3
Andrew Reynolds1
Tool not toll.
Andrew Reynolds1
Re-numbering door numbers, window number and furniture in large developments.
With large buildings doors and windows numbers that require renumbering to be sensible can be time consuming at early Tender stages, as can be furniture? Can this be done by selecting the doors and numbers, drawing a path start and finish on screen and adding a starting character such as 'W', 'D', 'W-100' or 'W-00..' user specific. can this be another tool? Door numbers are usually sensibly numbered clockwise or anticlockwise from a start point on the drawing.
