ā2004-11-27 11:12 PM
ā2004-11-28 01:43 AM
ā2004-11-28 01:59 AM
ā2004-11-28 07:42 PM
Ian wrote:If it is not an irregular shape, why not use the beam tool?
Does anyone know why some objects seem to dissappear in section view? I'm using structural beams which appear OK in 3D and 3D marquee but when I cut a section through the beam - it dissappears. Any ideas?
ā2004-11-28 09:16 PM
ā2004-11-29 03:44 PM
ā2004-11-29 06:32 PM
Ian wrote:Oh, that is right then!
I wanted to use a specific structural section rather than just a rectangular object. The objects came from the ArchiCad 9 library "Steel Structure 9". The objects which were still visible when cut by the section come from Australian Essential Library - BHP Sections".
Ian wrote:As Ted noted, check the duplicates; if you do have duplicates, they will not show in S/E. Also, check whether the layer is not off in the layer combo - it is easy to put the objects on a wrong layer.
I have found a work-around however I'm interested to know why this happens in some cases and not in others.
ā2004-11-29 07:58 PM
ā2004-11-30 11:12 AM
ā2004-12-01 02:15 AM
