2004-11-27 11:12 PM
2004-12-02 09:09 AM
2004-12-02 09:38 AM
Ian wrote:Did you try re-saving them as 9 objects? That should help; this is a known bug (part of objects not showing when in marquee).
It is similar to the problem with stairs where they will sometimes dissappear in marquee 3d view whilst being visible in full 3d view. The dissappearing beam objects will also dissappear in 3d if cut by a marquee but will be visible if the marquee does not cut them.
2004-12-03 12:24 AM
Aussie wrote:Anyone? This is a serious problem for me as it occurs with a number of objects. I can do a workaround by rotating and mirroring but if another section looks backwards then the pronblem moves to the second section.
Please let me know if anyone can see both objects
Djordje wrote:Is opening and saving all that is needed to do this as i have done that? There was a command in the special menu to do this but I dont seem to be able to get that menu to show.
2004-12-03 01:16 AM
2004-12-03 01:31 AM
James wrote:Thanks James that does help me as it says something wrong with my system rather than the object.
John,
I could not see both upon opening the section, only the one on the left. Then I rebuilt the section, and both were visible. I cut a new section, and both were visible. After that I tried rotating, mirroring, etc, no disappearance. I tried with direct reading, and saving a library. Same result. I haven't observed the behavior you described in my own work. Probably not much help. Good luck,
2004-12-03 08:20 AM
2004-12-03 08:36 AM
2004-12-03 12:37 PM
2004-12-03 12:38 PM
2004-12-03 12:39 PM
