2023-05-15 08:45 PM
In Archicad 22 when I use an arched door, the hole in the wall it is square doesn't follow the arch of the door.it is not with a library part that happens, but with Archicad door library!!
Any help
2023-05-16 03:15 AM
Can you show an image of the object setting dialogue for the object you are using?
2023-05-16 03:22 AM
Odd... Arch Door 22? Please add your AC details and some general computer specs to your signature as some issues are version / os specific. Are you able to share a .pla?
Ling.
2023-12-20 02:51 PM
Hi everyone!
I have the same problem in my existing project using AC26 with Archicad library 26. The single leaf door is the only one that appears correctly.
I have tested them in a new AC26 file, every door type works fine.
Is there any solution for this? Thanks!
2023-12-21 02:05 AM
Looks to me like you will need to send that file to your local support for them to have a look.
If a new file in 26 works, then obviously it is a file specific problem.
Correct libraries not loaded (or maybe duplicate or unnecessary libraries loaded)?
Or maybe it is a Legacy setting?
Why 2 out of 7 work is a bit of a mystery.
That is why someone (support) will need to look at the file.
