Door Leaf in Error
Version 25
Door
D2 2Sidelight 25
The dialog asked for a leaf size but resonds with a model where it is using the dimension as the total size for both leafs.
I choose 3' leaf
and it gives me two 18" leafs(doors) totaling 3'
Eric Milberger, Architect | Master Planner
Minh Nguyen
Graphisoft Alumni
Graphisoft Alumni
Dear Eric,
Thank you very much for the report and I am very sorry about the issue!
To understand the situation better, would it be possible for you to make some screenshots of the door's settings? This would be a big help for our investigation.
Thank you very much, and I look forward to hearing from you!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
Here is the attached Door D2 2Sidelight 25
Notice I Have the door leaf set to 6' and it looks perfect
But that is not the leaf size as there are two leafs in this door. The leaf size would be 3' each
Minh Nguyen
Graphisoft Alumni
Graphisoft Alumni
Dear Eric,
Thank you very much for the screenshot, so I understood it correctly!
The Leaf Size number is equivalent to Leaf Dimensions in INT library (as the diagram under it suggests). But we can see that it might be misleading, when there are double doors or the doors are asymmetrical.
Thus, I entered a request to the development to fix it in the US Library.
I'm very sorry for the inconvenience! Please let me know if you have any questions!
Best regards,
Minh
Minh Nguyen
GRAPHISOFT
