‎2015-02-05
09:08 PM
‎2023-05-24
10:49 AM
Rubia Torres
‎2015-03-16 01:02 AM
DSquad96 wrote:
I am running into a problem with the doors within the module however. I have numbered the instance of the hotlink module "213". Within the module, I have named the door "A" so that the door will be named "213A" in the master file. This works correctly as when I look at the properties within the master file, the ID of the door is "213A". However, the door marker which is set to show the Door ID only displays "A" (see image). It is soooo close to working, but not quite there. Any idea how to fix this? Thanks!
ClaudiaDeGoede wrote:This issue happens because Graphisoft somewhat "rushed" the Master ID into ArchiCAD and didn't have time to make it available to GDL objects. Because zone markers are GDL objects they are not able to access the Master ID of the elements hence only the "A" showing up in the zone stamp in the original example.
I have the same issue....I understand that it will work in AC19.?......but I am not a GDL guru....so I'd like a step by step manual how to fix the marker if you are not a GDL guru....anyone?
Thanks!
‎2015-03-16 01:11 AM
‎2015-03-16 01:15 AM
laszlonagy wrote:Wow that one slipped in quietly! Thanks for the heads-up, that will come in very handy!
It is my understanding that this should work with the AC18 4020 update:
http://archicad-talk.graphisoft.com/viewtopic.php?p=235152&highlight=#235152
‎2015-03-16 01:19 AM
‎2015-03-16 01:22 AM
laszlonagy wrote:We only use custom zone stamps anyway so that will be fine.
Yes, but I think you will still have to modify those GDL objects.
‎2015-03-16 01:26 AM
‎2015-03-18 02:43 PM
laszlonagy wrote:Hi laszlonagy, ok but what to do if I am not a GDL guru??? Can someone edit the eg zone stamp 2 18 and the door 18 and make it available to download eg on bim components?....(GDL does not make much sence to me
Based on that post you may be able to modify your GDL code (if you are comfortable with it) and make it work in AC18.
‎2015-03-18 04:33 PM
