Door Stamp Issue
JGoode
I have created a door and a window stamp but I'm having an issue where the stamp gets placed upside down when placing doors/windows at a certain angle. Is this a setting I can change in ArchiCAD or is it something I have to build into the object? If I have to build it into the object, what would I have to use to determine whether it is flipped or not?
Thanks
ArchiCAD 23
Windows 10
6 REPLIES 6
If You open any opening stamp You will see something like that:
rrr = REQUEST ("View_Rotangle", "", angleViewRot)
totalRotate = (SYMB_ROTANGLE + angleViewRot)
if totalRotate > 360 then totalRotate = totalRotate - 360
and then before texblock
place something like that:
if not ((textAngle > 90.0001-90) and (textAngle < 270.0001-90))  then 	rot2 180 else rot2 0
 !here should go textblock and all transformations of the coords with apriopriate del's
del 1
the "-90" in the angle is optional - in this case I had to have the text _always horizontal_
Piotr
JGoode
Where did you get textAngle from?
thanks
ArchiCAD 23
Windows 10
JGoode
Ah, I've worked it out now.
Thanks very much for your help
ArchiCAD 23
Windows 10
Sorry it has to be declared before the request to avoid errors
Piotr
JGoode
Is there a way to get this to respond to the workspace orientation too?
Thanks very much
ArchiCAD 23
Windows 10
this request reads the rotated view angle
Piotr
