Door/Window markers
How can I set all the markers size, shape, text at once without changing all the units to the one that selects and displays when all are selected?
9 Replies 9
alemanda
Good question!
The answer is one of the things I don't like using the marker for doors and windows ...
eng. Alessandro Mandala - Italy
AC27 latest hotfix
Win 11 Pro 64bit
Ultra 9 275HX 64GB GeForce RTX 5070ti
I did discover that if I selected each of them one at a time in turn and then with the whole set selected changed the settings it worked without making all the windows the same (as the first selected).
Another random discovery: door panel thickness dimension settings are not set in the door opening dimension button, but in the general dimension set up.
Another problem: I often have doors that wont show up in the schedule or the door types elevations. Any thoughts?
Stress Co_
Make the Window tool active.
Select all (Command A on Mac)
Open the Window Selection Settings
Change the Dimension Marker/Marker Settings.
Windows should keep their original parameters (type/size)... but now have
the same dimension marker.
Marc Corney, Architect
Red Canoe Architecture, P. A.
My mistake was to command click on one window then find all then change the settings.
Aaron Bourgoin
Marc. They don't behave as we would instinctively believe. Changing the label type changes the size of the window/door.
BUG! DEFECT! much aggravation because of this this week. 40 townhouses to get out the door and I'm not having fun changing the labels.
Turning Door knobs on has the same effect, so it's not just the label.
This needs to get fixed. STAT!
Think Like a Spec Writer
MacBook M4Pro - 24Gb RAM
AC4.55 through 29 / AC29.2.1 USA
Rhino 8.34 Mac
MacOS Tahoe 26.5.2
Stress Co_
I haven't noticed the bug.
Did a quick test in AC18... and it seemed to work fine
Aaron Bourgoin
Yosemite?
I'm coming over. mind if i borrow your machine? :- )
Rhino 8.34 Mac
MacOS Tahoe 26.5.2
Stress Co_
No, still using Mavericks.
It that the deal, doesn't work with Yosemite?
Aaron Bourgoin
Tom's signature could tell the tale. If he had one that listed equipment. !
not sure Marc. this has happened to me a few times on this project. The first time I was't paying enough attention. And then I couldn't reproduce it. And then I could.
Now I'm having to create custom find and select searches for each type of door/window and each unit size.
Rhino 8.34 Mac
MacOS Tahoe 26.5.2
