2006-02-17
03:11 PM
2023-05-26
11:40 AM
Rubia Torres
2006-02-20 05:05 PM
Seiss wrote:I believe that the SE9 library was created/is maintained by people here in the US. The problem is that practices vary widely across the country and the myriad of different building methods, wall types, etc. makes a one size fits all library very difficult.
My question is this: why doesn't Graphisoft hire USA consultants to design USA libraries? I am not being sarcastic here, have you ever look through the objects library, half the crap in it I have never seen, and half the window objects are not in any USA catalog I have ever used. My advice to Graphisoft, just call up an Anderson window rep, get a catalog, and copy it. You will have 99% of all USA window configurations in your hands. It's really not that hard to do, a no brainer, if you just try.
2006-02-20 05:09 PM
2006-02-20 07:06 PM
Matthew wrote:I looked too quickly. It is the jamb extension that automatically matches the wall thickness, not the frame. So, you guys are correct that a frame=wall thickness option is not available in the SE9 windows.
Karl,
I'm still curious. Which doors and windows are working for you "out of the box"? Are your wood doors able to fit automatically to the wall thickness?
2006-02-20 10:14 PM
2006-02-20 11:36 PM
Seiss wrote:This is exactly where I was headed with the multiple macro idea. It seems like something that could be done in the short run leading eventually to a full assembly editor. I agree that the fundamental problem here is that the door/window tool treats the elements as discrete entities when they are very often complex custom assemblies.
Thus, what is really needed is an assembly tool that allows the user to build door and window "openings" by browsing through standard library parts like the door and window objects, with their associated sashes, frames, muntin and mullions, and assemble them with other objects from the library which are not part of the window or door, such as jamb extensions, brick moldings, casings, sills, stools, etc., found in the MSA detailed library, and build a door or window opening, which then can be displayed and replicated as an object itself. I think this is called "model building", and here we would build a model inside the model.
In such a system Jay Garbarino could put outside trims over his exterior siding and I could chose to butt my siding to the trims. Just as in real life, the assembly of the objects is distinct from the objects themselves.
2006-02-20 11:46 PM
2006-02-21 04:29 AM
Matthew wrote:... or to mark them as one, with one marker - as they would have to be marked. SE or Int library, does not make a difference.
To their credit, the developers of the SE library did a nice job of making it possible to gang the doors and windows and still have the trims work, which gives us a bit of the assembly function. It's too bad there is no way to group the openings to move them as a unit though.
2006-02-21 08:14 PM
Seiss wrote:My problem has been with getting the SE Lib to replicate the Exterior trim that almost 90% of the "Standard" Home has here in the Mountains. We do not use Exterior Sills (Almost Never). getting the exterior trim to Just "picture frame" the Window has proven to difficult for me with the SE Lib. I even read through the PDF docs on the SE Lib.......
This seems strange to me as the SE9 library was billed as a USA library. A drywall jamb return with a wood sill and apron is probably the most common interior window finish used in USA production housing. In my custom work, many clients like 5/8" drywall with a 2" bullnose return used in combination with a 2x6 exterior wood stud wall. I can't do that with with the SE9 library.
2006-02-22 10:04 AM
2006-02-22 12:36 PM
