Door display wrong dimension (automatically minus 56mm)
Hi everyone,
For some reasons, my door displays the dimension less 56mm than original dimension. So for example, my door width is 1440mm, the display number on 2D plan will be 1384mm. When you click in the door, the dimension still stays the same on Door Selection Settings, it's just the name that changed.
Your marker is currently set to show the 'Leaf Dimensions'.
You can change it to show the 'Wallhole Dimensions' or something else if you wish.
5 REPLIES 5
Hello Anh le,
Do you check about which kind of dimensions you are talking about ? One of the first door parameters deals with it. There are 5 or 6 different ways to input door dimensions.
Christophe - FRANCE
Archicad Designer and Teacher
Archicad 15 to 28 FRA FULL
OS 13 Ventura - MacBook Pro M2 max- 32Go RAM
Christophe wrote:
Hello Anh le,
Hi Christophe! It's the width of the door, I have attached a photo. As you can see my width is 1440mm but in the dimension marker the number is less 56mm. The dimension marker number will be changed in response to whatever number I put it for width.
Thank you so much Barry, my problem is fixed. I am just starting so have a lot to learn.
Good luck.
I have been using Archicad for 20 years, and I am still learning.
