Door display
Hi! there is away to show the double door with one panel closed in the floor plan? in archicad 20?
Thanks
5 Replies 5
Steve Jepson
IFC Double Door - Single Swing ?
Search Library for - Double Door
Thank you so much!!!!!
But it is possible to add a custom panel?
Happy Halloween
Erwin Edel
You can set the opening angle of the symbol for both leafs for floorplan display, if that is what you mean? Set one to 0. This works for the more detailed doors (not the IFC simple ones), should be able to pick any panel. There is also assymetric double door to pick from if you want two different panels.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
I don't see any place to change on custom panel may be we have different library. I am using USA lib
Erwin Edel
Dutch library, but the parts are, as far as I know, just the same as the international library, but translated. I can find the ArchiCAD17 part on BIMcomponents, for example, just search in the object dialogue screen for 'asymmetric'
www.leloup.nl
