Tom Krowka
Door surfaces
Am not able to change surface materials on some doors wood internal doors and garage doors. Also the materials on the masonry arch. Is anyone else having this problem or do I have a global setting incorrect someplace.
It seems like the older versions....where there was a button for all materials to be the same. I can't seem to turn it off. Have toggled the switch for uniform materials on the door leaf dialogue box....but it seems to stay on (using uniform materials). If I turn it off, I can change materials in the dialogue box but nothing actually happens to the door.
Thanks.
Tom Krowka Architect
Windows 11, AC Version 26
[email protected]
www.walshkrowka.com
6 Replies 6
David Maudlin
In the Door Settings, check the Model panel, there is a Surfaces Override option there.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Tom Krowka
That's where the problem lies. When that box is unchecked, assigning different materials has no effect.
[email protected]
www.walshkrowka.com
Billy Earnest
I'm having this problem in AC21. I've got some doors that have glass, but no matter what I try, the entire door shows up like brown paint. I can't get the leaf, frame, glass materials to override, no matter what I do. In this file, the old library doors do the same as the newly inserted library doors.
I've checked that box on/off, it makes no difference. Why do we have to redoing these same things over & over? It's making me crazy!
Anybody got any ideas? Thanks in advance!
iMac & MacBook Pro
Billy Earnest
I found the solution in a setting that was not only turned off/on the wrong way, but not even showing by default! Geez....
Work Environment > Tool Schemes > Tool Settings Dialog Boxes > Door Tool > Model and make it visible.
iMac & MacBook Pro
Tom Krowka
wow. Good catch. Always good to find an answer.
Tom
[email protected]
www.walshkrowka.com
Billy Earnest
I wish they wouldn't change/hide all these ridiculous settings when the rewrite the stuff every couple years.
So far, working with AC21...overall, I like it better, but I prefer the door/window interface from 18. It made more sense to me then....quite an improvement from the prior versions. Now it's back in random kookoo land. Looks to me the difference when pure programmers write something vs. when people who actually use the software & know how to put buildings together write it.
iMac & MacBook Pro
