ā2015-08-26
04:57 PM
ā2023-05-24
10:48 AM
Rubia Torres
ā2015-08-27 02:38 PM
Tom wrote:In the Door Settings, check the Model panel, there is a Surfaces Override option there.
It seems like the older versions....where there was a button for all materials to be the same. I can't seem to turn it off. Have toggled the switch for uniform materials on the door leaf dialogue box....but it seems to stay on (using uniform materials). If I turn it off, I can change materials in the dialogue box but nothing actually happens to the door.
ā2015-08-27 03:10 PM
ā2017-11-27 01:27 AM
Tom wrote:I'm having this problem in AC21. I've got some doors that have glass, but no matter what I try, the entire door shows up like brown paint. I can't get the leaf, frame, glass materials to override, no matter what I do. In this file, the old library doors do the same as the newly inserted library doors.
That's where the problem lies. When that box is unchecked, assigning different materials has no effect.
ā2017-11-27 01:52 AM
Billy wrote:I found the solution in a setting that was not only turned off/on the wrong way, but not even showing by default! Geez....Tom wrote:I'm having this problem in AC21. I've got some doors that have glass, but no matter what I try, the entire door shows up like brown paint. I can't get the leaf, frame, glass materials to override, no matter what I do. In this file, the old library doors do the same as the newly inserted library doors.
I've checked that box on/off, it makes no difference. Why do we have to redoing these same things over & over? It's making me crazy!
Anybody got any ideas? Thanks in advance!
ā2017-11-27 08:00 PM
ā2017-11-27 08:17 PM
