Door tags
Have exterior info '014' in door tags when they are in exterior wall of two story structure. What is this and how do I get rid of it.
Thanks
4 REPLIES 4
David Maudlin
robertf:
Which door marker are you using? How is the "014" exterior info?
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
David,
The door tag I'm using is 'door marker USA 19'. I probably didn't frame my question properly, this additional code to my tag only is generated when I'm doing exterior doors and in this particular case it is a two story structure. I don't know if that has anything to do with it, but I don't have this problem in doing single story structures.
Thanks for your help,
Bob
David Maudlin
Bob:
I am guessing a bit here, but look at Door Settings > Dimension Marker > Customize Texts > Marker Text and see if it is set to Room & Door ID. It may be picking up some Zone information. You can set it to Door ID.
Dave,
Your guess was a good one. It was picking up the room ID as well as door. It's was one of those pesky things I couldn't resolve.
Thanks for all your help
Bob
