2024-09-24 09:59 PM
I am trying to create a door with an angled top. There si no standard door object that allows for this (as there is one for windows) and when I try to create a custom door leaf, the leaf is correct, but the casing does not follow sit, like this:
Any solutions out there?
Thanks,
Phil
Operating system used: Mac Intel-based BigSur 11.6.5
Solved! Go to Solution.
2024-09-25 03:34 AM - last edited on 2024-10-04 07:21 PM by Laszlo Nagy
You will need to create a custom Door element (frame and all) from slabs in the plan view.
This may help ... https://help.graphisoft.com/AC/27/INT/index.htm?rhcsh=1&rhnewwnd=0&rhmapid=#t=_AC27_Help%2F040_Eleme...
2024-10-02 01:52 AM
Ahh - makes sense, thank you!
