‎2004-01-29
09:50 PM
‎2023-05-26
11:48 AM
Rubia Torres
‎2004-01-30 12:33 AM
‎2004-02-04 11:01 PM
‎2004-02-04 11:14 PM
‎2004-02-05 01:09 PM
johncassel wrote:AFAIK no, as it fits whatever the size door/winow is into the space defined within the Graphical template.
Is there a way to force ArchiCAD's Door Legend (80) to produce the image at a common scale for all doors?
‎2004-02-05 06:32 PM
Now that I'm generating the Door Legend (Door Legend 81) I've noticed that the doors are of different scales depending on the size of the door. Is there a way to change some setting so that all of the door's images are produced at the same scale?I have in the past copied those doors and using the resize tool make them the correct size. I still do that for my door elevations, and then add dimensions etc.
