Double curvature, ideally solid
I need to model these funky precast panels and use them in ArchiCAD. I am told they are not hard to model in Sketchup, but that they will get all messed up when bringing them into ArchiCAD.
So would the C4D add-on be the only way?
42 REPLIES 42
Olivier wrote:
It seems that the complete model is recalculated for any type of SEO.
If your first concern is speed, the best choice is to model the complete mesh.
Yes, SEOs, GDL SEOs and good old WALLHOLEs are a disaster in terms of speed. For objects that will repeat a lot it is best to stay away from all that whenever possible, for a few objects in the model it will not make a difference.
Have you tried the Mesh 3D object in the GDL object library on this site?
http://archicad-talk.graphisoft.com/object_depository.php?&sid=461467aa5bd944e046399acce922f341
it's fairly versatile and easy(and quite fun:) to use - just start off slow with it and add points as you require further accuracy.
ok, so the link above doesn't work - the 3D mesh can be found in:
13 Special Construction > Basic Shapes
