Durval
Downgrading Library Parts from 9.0 to 7.0
Is there any trick to save an object created in AC9 to be used in AC7?
The script of the object to be converted is AC7-compatible, of course (new commands were not used).
--- www.dtabach.com.br ---
AC 28/29 BRA – MacBook Pro Apple M2 16GB RAM Mac OS Sequoia
3 Replies 3
TomWaltz
I have tried a few times, and have not been able to do so.
Tom Waltz
The only way I know of is to copy each of the scripts
into a text application and paste the code into a new
library part created in the earlier version.
Then tediously make an identical parameter list.
Peter Devlin
Ben Odonnell
Peter,
That almost sounds like it would hurt to do.
Durval,
If the scrips are ArchiCAD 7.0 compatible, can't you just simply load the old ArchiCAD 7.0 library? Or am I missing some thing?
Cheers.
Ben
Ben O'Donnell
Architect and CTO at BIMobject®
Get your BIM objects from bimobject.com
