Drawing Title in Archicad 18
Since Archicad 10 the Drawing Title preferences (NCS Drawing Title) one could change each set of text individually, but I don’t seem to be able to do that in Archicad 18. Does any one have a solution. the drawing Title and the scale are all the same text points and I can not change them individually.
undefined
Dontknow
Found some info on the subject here.
The first two lines say enough I think.
You can put in a title at your drawing in a layout.
When you right-click your drawing you can go to 'Drawing Selection Settings' and modify your settings there:
Architectural construction designer, draftsman, modeller
ArchiCAD 25.
David Maudlin
assieh:
In AC18 (I didi not check AC17), uncheck "Uniform Text Format" and each text item will have a Font Size parameter.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
