TLOTrike
Duct Obstruction 27 object defaults to "Rise"
I'm using ArchiCAD 28 Studio on Windows 11 and have modelled the ventilation ductwork for a house.
Everything works fine except for the Duct Obstruction 27 object always defaults to "Rise" even after you select "Drop" anyone know of a fix?
Only thing I can think of is convert it to a morph and flip it over but I would prefer a fix to the GDL code if possible.
Windows 11 ArchiCAD 28.3.0 (earliest version used ArchiCAD 3.4)
3 Replies 3
If this issue does not resolve, please report it to your local reseller.
@TLOTrike
You mention Archicad Studio.
Is that duct obstruction object a MEP object?
If so MEP does not work in the Studio version of the software as far as I know.
I believe you can see it, but you can't manipulate it.
Graeme
MEP works in AC28. It doesn't work in AC29, sadly.
As I couldn't get it to behave so I resorted to converting it to a morph and flipped it over that way.
ArchiCAD 3.4 - 28
Windows 11
