ā2005-05-27 11:45 PM
ā2005-05-28 01:42 AM
ā2005-05-28 02:25 AM
ā2005-05-28 09:03 PM
ā2005-05-31 07:52 PM
James wrote:
OK, I might have read the question differently.
The third object geometry method button gives a two click rectangle. Side lengths can't be entered. The fourth button is a typical rotated rectangle; first click is insertion point, second gives angle and length of one side, third gives length of second side. Values can be entered for both sides.
This goes for objects that are written with hotspots at A&B extents. If the length and width are stretchy by graphical hotspots instead, then you have to stretch after placement. Only A&B can be set dynamically.
When placing a stretchy object, um, stretchily, as above, a stretchy hotspot must be the insertion spot as shown in the preview window in the settings dialog. Otherwise you get simple or rotated placement.
There's no stretchy Z placement method that I know of.
Unless I misunderstand...
ā2005-06-02 04:53 PM
Ned wrote:I thought I could.
Can you explain this?
ā2005-06-02 04:57 PM
James wrote:Strike that.
