Edit Triple sash Window
The AC22 Triple Window makes the side transom windows an awning type. I want them to be fixed. I cannot find any way to do this. Is this possible? My preference would be to use OTB windows for the moment while I try to figure out the rather non-intuitive editing functions of Cadimage. I could turn off the opening lines but would like to have them in the elevations.
Kris
Lingwisyer
Guru
My library does not include a Triple Sash Window, but with Triple Window 22 there is an opening type option for each pane under Window Settings & Opening.
Ling.
Lingwisyer
Guru
Ling.
Perfect. Thanks for that. That window isn't in the US version but doing a search pulls it up (as well as some other interesting things). I have to remember to use the search function. Lots of good things are out there which aren't in the US version.
