OK, I wasn't clear enough then:)
GDL interpretation is done when ArchiCAD wants to generate a 2D or 3D model (among some other situations I don't mention here) of an object. The trick is that this is done only once for each parameterization of each library part. This means that if you place 100 pieces of the same library part with the same parameters, only one GDL interpretation will be done, but the 2D model of the element will be created 100 times. Fortunately, the 3D engine of ArchiCAD knows this trick too, consequently the total size of the 3D model won't be 100 times bigger.
I guess I haven't made my point any clearer... The point is that GDL interpretation time
is
an important concern but the quality and the size of the final model can be the same.
HTH,
Zsolt
Zsolt Táskai
ArchiCAD Development - GDL Team
AC13, AC14 and upwards...
