Showing results forĀ
Search instead forĀ
Did you mean:Ā
Search instead forĀ
Did you mean:Ā
Elevation Label 19 - Sea Level
Can someone help me modify the Elevation Label in 19 so that it can reference Sea Level or Altitude rather than just the Project Origin and Current Storey.
I've tried myself but I just don't have the GDL knowledge, so I get pretty lost.
2 REPLIES 2
That sure would be great. I could use something like that as well.
Erika Epstein
Another option:
Using the dimension tool the last construction method on the right is ELEVATION.
After placing, select ONLY the TEXT and open the settings box.
The Autotext allows you to choose the option for "Sea Level". With it you can also either write in in the CUSTOM TEXT box "Sea Level" or choose the ALTITUDE autotext.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
