Elevation Marker – Problem!
txt=str ("% +m",y~)
pen 1
text2 0,0,txt
How to fix values «txt» that at moving they not change?
6 Replies 6
Create two variables such as "Text":
dimText1
dimText2
Write in the Master a script:
HOTSPOT2 0, 0
DEFINE STYLE "dimText1"   Arial, 3, 8, 0
DEFINE STYLE "dimText2"   Arial, 3, 2, 0
Identify = ""
Identify = STR("%m", SYMB_POS_Y)
IF glob_context < 20 AND glob_context <> 5 THEN
	PARAMETERS dimText2 = Identify
ENDIF
dimText1 = STR("%m", SYMB_POS_Y)
STYLE "dimText1"
	TEXT2 0, 0, dimText1
STYLE "dimText2"
	TEXT2 0, 0, dimText2
In АС10 this script works. It works as follows.
dimText1 always shows current SYMB_POS_Y.
dimText2 will show SYMB_POS_Y, only when the library part will be placed on the plan or a section.
If this script will is included in a library part which can to be stretched, after extension dimText2 again will show SYMB_POS_Y.
Frank Beister
But it is not possible to store the XY-Position the object originally was positioned, isn't it? You have minimal to stretch it one time to store the position into dimtext2.
Greeting, F. Beister.
I am not confident that correctly has translated your message. But I shall try to answer.
Yes. It is not possible to store. dimText2 accepts value from Identify during that moment when the object will be placed on the plan. Repeatedly it can accept value when the object will be stretched. To check up my words, add in a script one more point: HOTSPOT2 A, B
I have taken a mentioned below script from " Object Label ", but it is possible to write it easier.
HOTSPOT2 0, 0
HOTSPOT2 A, B
PARAMETERS dimText2 = dimText1
STYLE "dimText1"
STYLE "dimText2"
It is possible to apply " IF glob_context <> 5 THEN PARAMETERS dimText2 = dimText1 " to see dimText2 in a settings dialog.
Ask more simple phrases, please, if I have not understood your question.
Frank Beister
There are limitations about the usage of SYMB_POS_X and SYMB_POS_Y. Both are 0 if you are in GLOB_CONTEXT=5. Unfortunatly the PARAMETERS-statement works normally only if GLOB_CONTEXT=5. What's new for me is, that obvisiously there is a situation, when PARAMETERS do work and the both parameters have the correct value. It has to be in Floor plan situation, but I have no idea how to check this situation by environment parameters.
I have changed your script to store all global position parameters separete:
HOTSPOT2 0, 0, 01
HOTSPOT2 a, b, 02
DEFINE STYLE "oben"   Arial, 3, 8, 0
DEFINE STYLE "unten"   Arial, 3, 2, 0
IF GLOB_CONTEXT>1 AND GLOB_CONTEXT<5 THEN
  PARAMETERS ePOSx=SYMB_POS_X, ePOSy=SYMB_POS_Y, ePOSz=SYMB_POS_Z
  ENDIF
STYLE "oben"
   TEXT2 a/2, b/2, STR("%m", SYMB_POS_X)+"/"+STR("%m", SYMB_POS_Y)+"/"+STR("%m", SYMB_POS_Z)
STYLE "unten"
   TEXT2 a/2, b/2, STR("%m", ePOSx)+"/"+STR("%m", ePOSy)+"/"+STR("%m", ePOSz)
I have loged the environment parameters when object is inserted into plan:
[log-format: time•script-type•context•global parameter•local parameter]
Selection in Object dialog box:
08:47:46 • Parameter-Script • Settings • SYMB=0,000/0,000/0,392 • ePOS=0,000/0,000/0,000
08:47:46 • Interface-Script • Settings • SYMB=0,000/0,000/0,392 • ePOS=0,000/0,000/0,000
08:47:46 • 2D-Skript-Script • Settings • SYMB=0,000/0,000/0,392 • ePOS=0,000/0,000/0,000
Built 2D view after closing dialog:
08:47:48 • 2D-Skript-Script • Floor-plan • SYMB=0,773/0,000/0,392 • ePOS=0,000/0,000/0,000
08:47:48 • Parameter-Script • Settings • SYMB=0,000/0,000/0,392 • ePOS=0,000/0,000/0,000
Resizing the object:
08:48:00 • 2D-Skript-Script • Floor-plan-Edit • SYMB=0,773/0,000/0,392 • ePOS=0,000/0,000/0,000
08:48:00 • 2D-Skript-Script • Floor-plan • SYMB=0,773/0,000/0,392 • ePOS=0,000/0,000/0,000
08:48:00 • Parameter-Script • Floor-plan • SYMB=0,773/0,000/0,392 • ePOS=0,000/0,000/0,000
08:48:00 • Parameter-Script • Floor-plan • SYMB=0,773/0,000/0,392 • ePOS=0,773/0,000/0,392
08:48:02 • 2D-Skript-Script • Floor-plan-Edit • SYMB=0,773/0,000/0,392 • ePOS=0,000/0,000/0,000
08:48:02 • 2D-Skript-Script • Floor-plan • SYMB=0,773/0,000/0,392 • ePOS=0,000/0,000/0,000
08:48:02 • Parameter-Script • Floor-plan • SYMB=0,773/0,000/0,392 • ePOS=0,000/0,000/0,000
08:48:03 • Parameter-Script • Floor-plan • SYMB=0,773/0,000/0,392 • ePOS=0,773/0,000/0,392
08:48:03 • 2D-Skript-Script • Floor-plan • SYMB=0,773/0,000/0,392 • ePOS=0,773/0,000/0,392
08:48:03 • Parameter-Script • Settings • SYMB=0,000/0,000/0,392 • ePOS=0,773/0,000/0,392
My goal is to store the global position of an object in the moment it is placed in floor plan. This position may never change afterwards! For this I do not see a way. Do you?
Funny thing beside: SYMB_POS_Z has ALWAYS a correct value!
My way the following. I apply the same method as well as with texts of the sizes.
When we want, that the text of the size did not change, we switch in position "Custom Text" in Dimension Text Setting. Then we change the size of object, but the text in size remains without changes.
It is habitual for user ArchiCAD. In a library part it is possible to apply this method also.
Part of a script from my library part "Level Dimension".
Variables such as "Text":
txtOption
customTextDimY
VALUES "txtOption" "Measured value", "Custom Text"
DEFINE STYLE "dimText"  nameFont, sizeFont, anchor, typeFont
TextDimY = STR("%m", SYMB_POS_Y)
IF GLOB_CONTEXT <> 5 AND txtOption = "Measured value" THEN
	PARAMETERS customTextDimY = TextDimY
ENDIF
IF txtOption = "Measured value" THEN
	dimText = TextDimY
	LOCK "customTextDimY"
ELSE
	dimText = customTextDimY
ENDIF
STYLE "dimText"
   TEXT2 0, 0, dimText
That is OK!
It's working!
Respect Valery W.
Respect F. Beister.
