2007-01-24 08:42 PM
2007-01-24 11:59 PM
HOTSPOT2 0, 0
DEFINE STYLE "dimText1" Arial, 3, 8, 0
DEFINE STYLE "dimText2" Arial, 3, 2, 0
Identify = ""
Identify = STR("%m", SYMB_POS_Y)
IF glob_context < 20 AND glob_context <> 5 THEN
PARAMETERS dimText2 = Identify
ENDIF
dimText1 = STR("%m", SYMB_POS_Y)
STYLE "dimText1"
TEXT2 0, 0, dimText1
STYLE "dimText2"
TEXT2 0, 0, dimText2
In АС10 this script works. It works as follows.2007-01-25 10:59 AM
2007-01-25 10:20 PM
F. wrote:Yes. It is not possible to store. dimText2 accepts value from Identify during that moment when the object will be placed on the plan. Repeatedly it can accept value when the object will be stretched. To check up my words, add in a script one more point: HOTSPOT2 A, B
But it is not possible to store the XY-Position the object originally was positioned, isn't it? You have minimal to stretch it one time to store the position into dimtext2.
HOTSPOT2 0, 0
HOTSPOT2 A, B
PARAMETERS dimText2 = dimText1
STYLE "dimText1"
STYLE "dimText2"
It is possible to apply " IF glob_context <> 5 THEN PARAMETERS dimText2 = dimText1 " to see dimText2 in a settings dialog.2007-01-26 09:12 AM
HOTSPOT2 0, 0, 01
HOTSPOT2 a, b, 02
DEFINE STYLE "oben" Arial, 3, 8, 0
DEFINE STYLE "unten" Arial, 3, 2, 0
IF GLOB_CONTEXT>1 AND GLOB_CONTEXT<5 THEN
PARAMETERS ePOSx=SYMB_POS_X, ePOSy=SYMB_POS_Y, ePOSz=SYMB_POS_Z
ENDIF
STYLE "oben"
TEXT2 a/2, b/2, STR("%m", SYMB_POS_X)+"/"+STR("%m", SYMB_POS_Y)+"/"+STR("%m", SYMB_POS_Z)
STYLE "unten"
TEXT2 a/2, b/2, STR("%m", ePOSx)+"/"+STR("%m", ePOSy)+"/"+STR("%m", ePOSz)
I have loged the environment parameters when object is inserted into plan:2007-01-26 07:51 PM
VALUES "txtOption" "Measured value", "Custom Text"
DEFINE STYLE "dimText" nameFont, sizeFont, anchor, typeFont
TextDimY = STR("%m", SYMB_POS_Y)
IF GLOB_CONTEXT <> 5 AND txtOption = "Measured value" THEN
PARAMETERS customTextDimY = TextDimY
ENDIF
IF txtOption = "Measured value" THEN
dimText = TextDimY
LOCK "customTextDimY"
ELSE
dimText = customTextDimY
ENDIF
STYLE "dimText"
TEXT2 0, 0, dimText
2007-01-29 06:19 PM
