2005-04-11 07:48 PM
2006-12-02 07:33 PM
2006-12-02 10:40 PM
GSNA wrote:I wonder what you'll be doing after 20 days of experience! Great job!!! I'll try to use it better monday at work.
Any comments are appreciated since this is my first 20 min experience with gsm objects.
2006-12-03 11:44 PM
2006-12-03 11:46 PM
2006-12-04 10:52 AM
2006-12-06 04:09 PM
PatriciaLeão wrote:Hey Patricia,
Markus,
I put your section marker instead the other (Tom's AC9 version), and it worked the same way, wich means... I still didn't get the page number on marker. Am I, as usual, missing something? It seems the same marker to me...
andyro wrote:Thank you for pointing out copyrights and yes you are 100% right about that. As Tom wrote he published it before to the public, which gave me the reason to believe it will be ok to modify the object. This is a appeal to everybody respecting copyrights. Thank you Andyro for beeing so wary.
This object was created by Thomas Waltz, and is copyright protected. How did you get it? As I am pretty confident Thomas is not selling his custom work for KA, I am sure he will have something to say about this. (edited) -I wasn't aware you had shared this Tom, thanks for clarifying...I should have read the whole thread!!
2006-12-06 04:24 PM
2006-12-06 05:31 PM
GSNA wrote:
I am assuming you are missing to select the checkbox "refer to drawing"
2006-12-06 05:39 PM
2006-12-06 07:26 PM
TomWaltz wrote:
Are you familiar with how the object's keying system works?
In order to prevent 4 instances of text, I added a system so that only the first elevation in the sequence gets the sheet & number text. The first one in the sequence is determined by a parameter under "Use Autoletter" called Elevation "key"
The default is "A". You should probably change it to "1"
BTW, I just realized a mistake I make and re-uploaded the object. You should grab the latest update so you have pen control.
