Elevator object problem
I'm having a problem with the Elevator 2 object in AC8. For some reason the second storey floor to floor height is produced at a different level to that set in the parameters. This then throws out the rest. Has anyone encountered this and are there any suggestions?
1 REPLY 1
Greg Kmethy
In the elevator object's settings dialog there is a tab page called 'Story and Opening Type Setting'. On this tab you can select how many stories you have, then you can cycle through the stories in the 'Actual Story' window and set 'Story Height' parameter for each. This should do it.
HTH,
Greg
Gergely Kmethy
