In the elevator object's settings dialog there is a tab page called 'Story and Opening Type Setting'. On this tab you can select how many stories you have, then you can cycle through the stories in the 'Actual Story' window and set 'Story Height' parameter for each. This should do it.
HTH,
Greg
Gergely Kmethy
