albertosc
Erase solid gray hatch from Toilet ADA Object
How can I remove the gray solid hatch from the floor of the ADA Toilet object? I've already tried Graphic Overrides and editing the 2D Script with ChatGPT, but neither has worked, and if I explode it, they stop appearing in elevations. I need to do this with other furniture-type objects.
1 Solution
albertosc
albertosc
