Error in my window library?
Hey there-
I'm new to ArchiCAD (I'm using ArchiCAD 10) and I'm building a very small project to get my feet wet with the program.
When shifting between 3D views and plans or elevations, I'll get a warning message that says:
"Fill not found at line 523 in 3D script of file Casement_a.gsm"
This error pops up multiple times in a row.
Could someone give me some direction with how to deal with this error and possibly fix it?
Thanks in advance.
steve
4 Replies 4
A commonly asked question. This generally only happens if fills have been deleted, via the fills dialog or attribute manager.
Read various old threads to see how to track it down:
http://www.google.com/search?rls=en-us&q=%22fill+not+found%22+site:archicad-talk.graphisoft.com&ie=U...
In particular:
http://archicad-talk.graphisoft.com/viewtopic.php?p=134974
and
http://archicad-talk.graphisoft.com/viewtopic.php?p=131935
You may have to use the marquee to find which particular window is the problem, and then open its settings to see where a fill is listed as missing.
AC 29 USA and earlier   •   hardware key   •   macOS Taho 26.5 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Thanks Karl!
I think I've figured it out, but don't really understand how it happened in the first place.... at least now I can work around it.
Thanks again
steve
If you do a New and Reset All (CTRL+ALT+N) or start your project using an ArchiCAD Template File then no fills or any attributes should be missing.
rocorona
And, as quick solution, you can also do a New & Reset All, then MERGE your problematic file.
_________________
--Roberto Corona--
www.archiradar.com
AC18 - ITA full on Win10
_________________
_________________
