License Delivery maintenance is expected to occur on Saturday, October 19, between 4 and 6 PM CEST. This may cause a short 60-minute outage in which license-related tasks: license key upload, download, update, SSA validation, access to the license pool may not function properly. We apologize for any inconvenience.
Escape ladders
Does anyone know of any library parts for ext. escape stair? I have looked at objects on line and found only ship ladders. Thankyou
5 REPLIES 5
You could probably make one in Profiler in 10 - 15 minutes.
Grant
Does the Fuzzy ladders is what you want ?
See in this Topics http://archicad-talk.graphisoft.com/viewtopic.php?t=6864&postdays=0&postorder=asc&&start=10 .
HTH
TomWaltz
Do you mean like a fire escape that lifts up when it's not in use, like you see in walk-up apartments in large cities?
I don't know that I've seen anything like that.
Tom Waltz
Exactly, I haven seen any either. Someone said I can make one with profiler? I am not sure how to do it, probably with stairmaster. SanFrancisco codes are pretty stringent.
Assieh,
You can probably make this object using a combination of techniques.
There seem to be four elements composing the object.
The first element is the grate floor of the landings which can be made
with narrow slabs multiplied.
The second element is the railings which can be made using TrussMaker.
The third element is the steep stairs that can be made by using
slabs for the treads and and roofs for the stringers or use the ships ladder
and the handrails can be made with TrussMaker.
The fourth element is the vertical pull-down ladder to the street which
After you have made one assembly for one floor with one set of steps
going up to the next landing save the whole assembly (except the
pull-down ladder) as a library part.
Then you can stack these units vertically for each floor of your building.
These fire escapes come in a few standard sizes do they not ?
Therefor, going through the effort might be worth it.
Peter Devlin
