Explode a Library Object
Why When I explode a 2D Library that i create, all the circles turns to segments? and the same when i publish to DWG.
Any Help?
6 REPLIES 6
David Maudlin
Emad:
I just tried exploding 2 library parts with circles, one generated from a 2D Script and the other with a circle drawn in the 2D Symbol window. Both of these created circles when exploded. Maybe you can post the library part that is giving the segmented lines.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
I thought it might have to do with the magic wand settings but haven't been able to explode the arc to lines. I'm stumped.
What version of ArchiCAD are you using?
Aussie John
it is possible the library part is using the PROJECT2 command which views the plan view of a 3d model hence making a circle segmented
Cheers John
[/size]
Why didn't I think of that? (followed by forehead slapping)
Sounds like a good call John. The question remains about the DWG - unless it's just an artifact of the same part.
Here is the library object, by the way it doesn't happen with all the library parts!!
David Maudlin
Emad:
I got the same result: exploding this library part results in short lines instead of arcs. I opened the library part (it is earlier than version 9, the date of the part is 11 March 2000) and the profile is drawn in the 2D Symbol window, and it is composed of lines and arcs. I don’t know why this part explodes into short lines for the arcs. A workaround to get the arcs into your project:
1. Select the part and go to File>GDL Objects>Open Object… (you will get a warning about this object being from an earlier version of ArchiCAD if you are using version 9, click OK)
2. In the main library part window that appears, click on the button next to ā€œ2D Symbolā€.
3. The 2D Symbol opens with the profile drawn with lines and arcs. Select the Arrow Tool, Select All (Edit>Select All) and copy.
4. Go to the 2D Window or Section/Elevation Window or Detail Window where you want the profile and Paste.
5. The profile will be pasted with true arcs.
I don’t know why this part doesn’t explode correctly, maybe it is due to the complexity of the profile, or that it is from an earlier version of ArchiCAD.
HTH
David
