โ2016-07-25 12:05 PM
โ2016-08-05 09:29 AM
โ2016-08-14 08:43 AM
โ2016-08-17 10:46 PM
โ2016-08-18 11:33 PM
โ2016-08-19 07:55 AM
SumA1 = 0 !! initialize. FOR i=1 to points if i < points then A1 = x*y[i+1] if i = points then A1 = x*y[1] SumA1 = SumA1 + A1 NEXT i SumA2 = 0 FOR i=1 to points if i = 1 then A2 = x*y[points] if i > 1 and i < points then A2 = x*y[i-1] SumA2 = SumA2 + A2 NEXT i !Text2 1.2, 1.2, "A1: " + str(SumA1, 4,2) + "m2" !Text2 1.2, 1.1, "A2: " + str(SumA2, 4,2) + "m2" Summe = (SumA1 - SumA2)/2 !!! Calculate Text2 0, 0, "Area: " + str(Summe, 4,2) + "m2"
โ2016-08-19 01:24 PM
!!This is at the end of the code after the polygone code
for i = 1 to points-1 !! give the points from the Code from Esteban Ramos to the stack
put x, y
next i
call "PolygonOperations", !! http://www.graphisoft.com/ftp/techsupport/documentation/developer_docs/BasicLibraryDoc/15/Window-Macros/PolygonOperations.html
parameters opcode = 2, !! Point inside Polygone
srcPolygon1 = 2, !! Input from the GDL stack
result = 2, !! 1 = Output to a parameter (returned_parameter) 2 = to stack
pntX = Tx, !! Eingabe Koordinaten
pntY = Ty !! Eingabe Koordinaten
Ret = get(1)
if Ret = 1 then
circle2 Tx, Ty, 0.3
Text2 Tx, Ty, "inner"
endif
if ret = 2 then
circle2 Tx, Ty, 0.3
Text2 Tx, Ty, "outer"
endif
โ2016-08-19 02:48 PM
put x, y, put 1 !!!! HERE 3 Values has to be inserted !!!!
next i
Ret = get(1)
if Ret = 1 then
circle2 Tx, Ty, 0.3
endif
if ret = 2 then
circle2 Tx, Ty, 0.3
endif
โ2016-08-19 07:09 PM
