Extract global coordinates of the local coordinate system
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2015-01-23 07:13 PM
2015-01-23
07:13 PM
Sometimes (after numerous ROT and ADD's) it would be nice to know to coordinates og the local coordinate system.
7 REPLIES 7
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2015-01-24 01:24 AM
2015-01-24
01:24 AM
David wrote:Hi.
Is there a way to extract the global coordinates of the local coordinate system in GDL.
To use in what way? Solution might depend on the actual need.
The 3D view of the object (in the GDL object editor enviroment) will show the current position after the ROTs and ADDs transformations (provided you have them active). For the 2D view, I don't think there's that option.
For either one, you could create a small subroutine that draws 2 or 3 lines (for 2D or 3D) to show axis' position and rotation. This has proven quite useful in the 3D script when viewing several points at once that will be used later (to check the positions created in a script).
So if you move the coordinate system and you don't see it, you can GOSUB your axis' subroutine and keep modifying the script until you get the position you want, then comment out the GOSUB.
Best regards.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2015-01-24 08:15 AM
2015-01-24
08:15 AM
Well, to be more precise.
I'm working on a automated drain pipe model in 3D.
I have a start point i 3D and an end point in 3D.
The drain pipe goes from the start point to the end point following certain rules.
I would like to check the difference between the end of the pipe and the end point (if any🙂 , and being able to extract the global coordinates of the local coordinate system would make that a lot easier 🙂
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2015-01-24 10:20 AM
2015-01-24
10:20 AM
Certain time ago I made an object for this. Take a look if it is useful for You.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2015-01-24 10:22 AM
2015-01-24
10:22 AM
For download:
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2015-01-24 10:53 AM
2015-01-24
10:53 AM
Well, it's a entire drain pipe system i'm working on (a bit more complex 🙂 , but thank you anyway.
I think the conclusion is that you can't get the global coordinates of the local coordinate sytem.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2015-01-24 09:52 PM
2015-01-24
09:52 PM
Have you tried Archicad's MEP?
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Mac OSX 10.11.1
AC5-18
Onuma System
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2015-01-26 03:58 PM
2015-01-26
03:58 PM
David wrote:Well... not exactly. It depends on how you are making the script work. Assuming that you control either the end point or the end of the pipe, you must be able to know or calculate each of the end positions. There is no "give me current axis position" command, but since you are moving the coordinate system to build your object, in essence, you always now the current position. Why don't you give the accumulated transformation values to a variable? It's a little difficult to provide more help without more information; and this is only if I'm understanding what you mean by being able to extract the global coordinates of the local coordinate system....
I would like to check the difference between the end of the pipe and the end point (if any🙂 , and being able to extract the global coordinates of the local coordinate system would make that a lot easier🙂 ....
...I think the conclusion is that you can't get the global coordinates of the local coordinate sytem.
Best regards.
