File name to long error
Hi
I am having a real problem... I am using AC 10. After a system crash I restored my files and since then I have received this error message every time a library file is accessed.
This is the message I am getting.
" The file or folder name is too long.
msa_cmustd.sash_8x8x16 top(1)/gsm"
the first line is the same
the second line is for the name of the library items from archicad.
Hope someone out there can help!!
Eric
2 REPLIES 2
Thomas Holm
If that message repeats itself for every library item, you're in trouble. Your restore didn't work as it should. Most library objects have a .gsm extension to their file names, seems the dot's been exchanged to a slash?
I would try to re-install Archicad with its libraries from the original CDs,and then download and apply the appropriate hotfixes. And pray that I've got a good backup for the office's own library parts.
Hi Thomas
I'll get right on that reinstall, I appreciate your quick response.
Let you know how it goes!!!
Regards
Eric
