Learn more
Kamelite
Fill-error when rendering a stair
I've created a stair with the stair-editor i AC. And in plan-view there is no problem. But when I'm switching to 3D-view, hitting F3 that is, I get an error Message that says: Fill not found at line 861 in script of file Stair 1.gsm
Then I can hit either Stop or Continue, but the stair doesn't render anyway. I've tried different textures etc, but they all give the same error.
The file stair 1.gsm is embedded in the pln file. Anyone have any idea of what the problem problem might be?
.Thag
This is in archicad 17, not 16 as the footer says 🙂
Windows 10, Archicad 28
1 Reply 1
David Maudlin
Kamelite:
Open the settings dialog box for the stair and go through the various parameters looking for a fill that is "MISSING", similar to this thread:
Library Parts Not Working Properly
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
