I've created a stair with the stair-editor i AC. And in plan-view there is no problem. But when I'm switching to 3D-view, hitting F3 that is, I get an error Message that says: Fill not found at line 861 in script of file Stair 1.gsm
Then I can hit either Stop or Continue, but the stair doesn't render anyway. I've tried different textures etc, but they all give the same error.
The file stair 1.gsm is embedded in the pln file. Anyone have any idea of what the problem problem might be?
.Thag
This is in archicad 17, not 16 as the footer says 🙂
Windows 10, Archicad 27,28 and 29
