Fit In Window command
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2017-08-29
11:54 PM
‎2023-05-26
02:15 PM
Rubia Torres
‎2017-08-29
11:54 PM
0.000000%. No matter how I try to tweet it, it goes to 0%. I have to use Zoom to Home to adjust my zoom. All other AC functions work with no problem.
Is there anything I can do to set this back?
Ben Ling
B.L.LING ARCHITECT INC.
Vancouver, BC, Canada
Mac Pro 3.5 GHz 6-Core Intel Xeon E5
AC 20
AC 20
5 REPLIES 5
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2017-08-30 03:13 AM
‎2017-08-30
03:13 AM
Does it do this on every file, or just a specific file / storey?
Bruce Walker
Barking Dog BIM YouTube
Mindmeister Mindmap
-- since v8.1 --
AC27 5060 INT Full | Windows 11 64 Pro | 12th Gen Intel i7-12700H 2.30 GHz | 64 Gb RAM | NVIDIA GeForce RTX 3060 32 Gb
Mindmeister Mindmap
-- since v8.1 --
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2017-08-30 07:42 PM
‎2017-08-30
07:42 PM
Bruce, it only happens with this particular file.
Other files working normally.
Thanks.
Thanks.
Ben Ling
AC 20
AC 20
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2017-08-30 08:51 PM
‎2017-08-30
08:51 PM
Then I would say what most likely has happened, is there is an element widely scattered from the rest of your model. If, at full extent, you do a select all, you may notice two different groups of hotspots. This should enable you to identify which element/s have gone rogue...
Bruce Walker
Mindmeister Mindmap
-- since v8.1 --
Mindmeister Mindmap
-- since v8.1 --
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2017-08-30 11:53 PM
‎2017-08-30
11:53 PM
I suspect this is the problem too. But Select All does not show anything.
By the way , Elevation and Section windows work fine.
Ben Ling
AC 20
AC 20
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2017-08-31 12:22 AM
‎2017-08-31
12:22 AM
I finally found that little dot far away from the building. Problem solved. Thanks.
Ben Ling
AC 20
AC 20
