Fixed dimension, changing size
Is it possible that you have the ability to deside around wich hotspots will the dimensions of the object change?
eg. see the picture
If I have this frame that has 15 cm "offset", would it be possible that this value (15cm) stays the same whole the time, meaning that I want the fame to change its dimensions just around its inner points?
So if I have, weight/height (W/H) 150x150 cm, offset is 15cm
If I have 70x70 cm, offset stay the same - 15cm
12 Replies 12
Can someone answer my question on ArchiForma regarding its control over created objects, couse I would realy like to avoid direct GDL language and its procedure, please
TomWaltz
ArchiForma is good for creating more complex objects that you could not easily make with Archicad's normal tools, but they still will not have parametric frame sizes or anything like that.
Tom Waltz
Thanx Tom
