2006-09-11 05:50 PM
jdk wrote:Speaking of those ...
I do not like fork lifts...
2007-10-06 11:56 AM
2013-12-31 10:52 AM
2013-12-31 09:42 PM
Hmooslechner wrote:And to clarify, this functionality is built into AC17 and above. Integrated Connections with Google Earth, Sketchup Get the add-ons for older versions: http://www.archicadwiki.com/SketchUp
You can import this in Archcad. in V16 - You need the Plugin for Google sketchup - download and install it - then You get a new menue within Archicad to import this things.
Hmooslechner wrote:To cleanup triangulation from imported objects see this article:
But there are som restrictions - If You import from Google sketchup - it will make GDLs with so much 3Dfaces You wouldnt be able to count..- which slows down Archicad.
