Forward Migration Parameter Change
JGoode
I finally got forward migration working but I have one small issue. Due to the fact that I have a parameter which contains the ArchiCAD version number the old value from the parameter carries through. Is there a way to change the parameter value when migrating? If so what it the script and in which object should I place it? The reference guide doesn't really explain very well.
Thanks
ArchiCAD 23
Windows 10
5 REPLIES 5
In the Migration script you just do the old parameter setting routine.
if actualGuid = _startID_1 then
archicad_ver = REQ("GDL_version")
PARAMETERS archicad_ver = archicad_ver
actualGuid = _endID
endif
I would use the REQ("GDL_version") but you could just hard code the number as well.
JGoode
actualGuid = _endID
endif
Hi, this didn't seem to work for me. No errors or anything, it just didn't work.
ArchiCAD 23
Windows 10
OK this is your code you posted before.
Fill in your GUID numbers and change "achicad_ver" for the name of the parameter you are using in your object for the version number.
actualGuid = FROM_GUID
 if actualGuid = "???????????" then
 endif
 SETMIGRATIONGUID actualGuid
It could also be because your version number parameter is not a numerical variable but is a string variable?
In that case just use ...
archicad_ver = "21"
JGoode
 endif
archicad_ver = "21"
I tried this exact code both the hardcode and the REQ command but neither of those worked for some reason. I just hardcoded it into my 21 object so it just refreshes script upon migration.
Thanks
ArchiCAD 23
Windows 10
The only other thing I can think of is you may need to check that the old object has the parameter and get its value before you change it.
xx = DELETED_PAR_VALUE ("archicad_ver", archicad_ver)
 endif
