Front and Side View of Furniture
Llian
I m looking for 2d elevation of seating...scan through the library and only 3D ...how do I get the elevation view of these furniture?
Lilian Seow LEED AP | cSBA | CAPM | PMP
AC 29 USA FULL | Windows 11 Enterprise i5 3.10GHz | Archicad-user since 1994!
1 REPLY 1
Place them in plan and your sections and elevations will show the correct side views.
If you are not using live sections and elevations for some reason or don't want to place them in plan then place them in plan off to the side (or in another storey or even a completely separate file) and create a new elevation looking at the side view you want.
Then open the section, place a marquee around the furniture and copy.
Now you can paste it into any view you want as 2D lines and fills.
