2018-11-09 12:31 PM
2018-11-10 05:56 PM
2018-11-10 07:20 PM
2018-11-11 12:55 PM
felcunha wrote:Thanks. Any idea where can I find someone explaining it?
You can't have 2D FRONT and SIDE views of an object.
All you can is to have plan views (or 2D) and 3D views, which suppose you'll insert your object directly into the section you want it to be shown.
Otherwise your section/elevation representation will always be the real 3D.
But a workaround could being able to select wich 2D view (PLAN, SIDE, FRONT) of your object you want to show in every view (since it will be a 2D object that will by definition only be present in the view you've inserted).
You can do it using GDL scripts, but it's not easy to do for beginners...
2018-11-12 03:41 AM
Piotr wrote:
The fastest:
1.Change to morph
2.Change all unwanted edges to the last option that does not break the surface
3.Save it back as object.
Piotr
| Win11 | i9 10850K | 64GB | RX6600 | Win11 | i9 11900K | 32GB | GTX2080TI |
2018-11-12 04:35 AM
2018-11-12 01:58 PM
2018-11-13 02:36 AM
2018-11-13 08:59 AM
