‎2008-07-01 09:11 AM
‎2008-07-01 10:20 AM
arunagwalani wrote:No.
If a GDL Object is created in a higher version of Archicad(example Archicad version 10 or 11) can it be opened in a lower version of archicad (example Archicad version 9 or 8.1)
‎2008-07-01 01:58 PM
‎2008-07-02 05:08 AM
‎2008-07-02 10:29 AM
arunagwalani wrote:You can convert GDL objects from one version of ArchiCAD to another (forwards and backwards) using the LP_XMLConverter tool from GS. This tool converts GDL objects to and from XML. You could, for example, convert AC11 objects to XML using the AC11 version of LP_XMLConverter, then convert back to GDL using the AC9 version of LP_XMLConverter. This tool converts everything - scripts, parameters, other data - but won't do anything to overcome scripting incompatibilities, e.g. new commands. For more info, take a look at this topic.
‎2008-07-02 12:12 PM
‎2008-07-03 04:49 PM
