2004-06-17
03:46 AM
2023-05-24
12:13 PM
Rubia Torres
2004-06-17 03:55 PM
Peter wrote:Files with the .gdl extension are just plain text files. You can create one with any text editor and save it with the .gdl extension (or save it as .txt and change the extension later to .gdl). Just make sure that whatever you use is really saving as
How do you save a simple 2D only library part as a gdl text data file?
I am guessing this is the problem since in AC 6.5 the library part to be
read had to have the file extension *.GDL.
2004-06-17 07:47 PM
2004-06-18 12:10 AM
Peter wrote:Odd - I can open .gdl files in 8 and 8.1. I've attached a trivial example file (test.gdl) - could you download it, unzip it, and see if you can open it from ArchiCAD?
Apparently, in AC 8, it is not permitted to "save as" *.gdl or to "open as" *.gdl.
2004-06-18 01:49 AM
2004-06-18 03:38 AM
Peter wrote:To create such a text file you now have to copy the text from the 2D script window and paste it into a word processor/notepad/textEdit and save as
The file I created was made by dragging and dropping a bunch of lines
into the 2D script window of a new "Untitled" object.
The only option for saving the object was as a *.gsm.
No option to save as *.gdl was available, unlike previous versions of AC.
