2023-07-14 09:00 AM
Is there a way to GDL code a 2d view in a way that it becomes automatically different according to the scale?
like for example if below 1:50 = view 1
if above 1:50 and below 1:100 = view 2
above 1:100 = view 3
same way as you have with model view options objects detail level?
Thanks
Bawar
Solved! Go to Solution.
2023-07-14 09:11 AM
Hi
one way:
IF GLOB_SCALE <= 50 THEN
! view1
ELSE
IF GLOB_SCALE <= 100 THEN
! view2
ELSE
! view3
ENDIF
ENDIF
another way would be
! view1
ENDIF
IF GLOB_SCALE > 50 AND GLOB_SCALE <= 100 THEN
! view2
ENDIF
IF GLOB_SCALE > 100 THEN
! view3
ENDIF
2023-07-14 09:11 AM
Hi
one way:
! view1
ELSE
! view2
ELSE
! view3
ENDIF
ENDIF
! view1
ENDIF
! view2
ENDIF
! view3
ENDIF
2023-07-14 09:48 AM
you are simply the best 😄
used the first method. i am a beginner with gdl but it is quite satisfying. that it works:D
if you have tips they are welcome:D
2023-07-14 09:57 AM
Horse 11 in the fifth race at Ascot.
It's a sure thing. 😉
Sorry I couldn't resist.
I was also going to say - "quit while your ahead". 🤣
2023-07-14 10:05 AM
Hahahahaha
Will share the price money with you, or split the losing 😄
Quitting is not an option hahaha
it works quite great, love the logic behind GDL, but there is a lot of learning for me to do.
Especially Graphic User Interface – I just don't understand how that works or the macros for example.
Anyway, I figured it is important to sketch the outcome you want
and write all the requirements of that object before you start coding.
It makes life easier.
2023-07-14 10:15 AM
GDL is quite simple yet quite complex at the same time.
The best investment I ever made was the GDL COOKBOOK 3 by David Nicholson-Cole.
It is very old (so not up to date) and you can't purchase it any more.
But if you Google it you will find a PDF version (4 which is a little more up to date).
The basics in the book are still all applicable - it just doesn't include some of the newer commands.
It has a few bits on the user interface.
I still refer to it some 20 odd years after it was published.
2023-07-14 11:04 AM
pretty sure, I'm not 😉 but i'm glad to be of help
besides bets on horseracing i basically use 4 different sources 😉
