Read more
Wishes
Adding Custom Scale in Work Environment Profile
jphanbit
If you go to View Map > View Settings > Scale, there are scales provided by default, and other
scales can be set and used whenever necessary, but each user has different frequently used scales.
It would be good to be able to add frequently used scales to the work environment profile and
use them like favorites. For example, 1/60, 1/80, etc. are often used, but since they are not in the
default value, it is inconvenient to have to input them every time you set them.
0 REPLIES 0
